Highest server level that can run on QNAP TS-659 Pro II?
Server Version#:1.9.6.4429
Player Version#: Roku 6.4.10.6174
On the Roku, it can’t talk to the version of the server running on my QNAP - it says 1.10.0 or higher is required. I don’t see an update for QNAP that will allow me to get to that level so I’m trying to understand if it’s even possible. Also, regarding compatibility, my model of QNAP, the TS-659 Pro II is not even listed on the compatibility matrix that you have published. Can you tell me if I can upgrade to a version of the server that is compatible with my Roku client?
That NAS will likely not be able to run PMS. It is an Intel Atom D525, very old. You can use it as storage for your media but will need another platform for PMS.
Since your QNAP sadly doesn’t support a 64Bit OS (QTS), then the latest version that was made for that was 1.14.1.5488
Sadly, Plex doesn’t provide an archive of older versions to download :frowning:
Thank you for the quick reply. Are you suggesting it’s unlikely I’d be able to find a server version I can run up to 1.14? Curious that QNAP wouldn’t provide it. Perhaps bittorrent?
This sadly
Edit: Check this post
Thanks again!
