I have a Netgear Nighthawk x10 with plex server installed. I also have a WinTv-dualHD usb tuner can I hook it up for plex live tv. If so How Thank You in advance.
You would need to be able to install the Hauppauge drivers on the x10. The Hauppauge site only shows Windows and Linux PC support for the device.
I show a Linux server as one of my Devices so the x10 might be using Linux so that gives me a direction to go thanks
Did you ever get this setup and working?
I never did get it working . I ended up getting HDhomerun Even with that I get a red light on my router from what I can find out that is because the HDhomerun can not keep up with the speed of the Nighthawk X10. Everything works I just get the red light.
If you use a shield use that or for a better setup buy a HDHomerun and connect that to the router port… this is the best setup…
The light is Amber… and I to though this was a problem when it was no… the port is not telling you your connected device is a 10/100 device…
All is good… this setup is the best.
