Home Videos - Text file for Info
I think this question has been asked, but I can’t find the right solution.
How to make Plex Media Server read local info files for Home Videos?
depends what “local info files” you’re talking about.
the most simple mode might be to use embedded metadata in mp4/m4v videos.
if you uns .nfo files from Kodi or a similar platform… check out the metadata/agent plugin section.
I mean Summary, dates something like that…
see above… if you use mp4/m4v files, you can edit the embedded metadata and enable it in plex (using local media assets and/or enabling embedded metadata).
if you have the data in a supported format, you could use a respective agent… this post started ages ago – you might need to check if the plugin is still up-to-date / working:
edit: personally I would embed the metadata right in the video files. this way nothing gets lost if (god forbid) your library gets corrupted and you need to re-load it from scratch.
i never used XBMC, i started with Plex and never really got into Agents, i found one but it’s tedious…
Oh well :slight_smile:
