Hope to fix PLEX scraper poster matching ad issue
Sorry, you are not making sense.
What does a poster have to do with an ad?
Could you provide some more detail?
Your files are in mp4 format? Quite likely these images are within your video files.
Edit your library, go to the “Advanced” tab.
Disable “Prefer local meta tags” in the properties of your library.
Do also disable “Use local assets”.
Then “Refresh Metadata” of the movie.
Ok, I’ll try it, thanks
