Horizontal Scrolling using plex-web is really annoying and totally unusable
Server Version#:latest
I really hate horizontal browsing. There should be an option in the web player to disable it . I have lots artists that have more than 30 EPs & Singles which makes the web interface on laptops and desktops completely unusable.
Same thing with Various Artists in Compilations & Soundtracks where I have to scroll horizontally more than 200 albums…
Music should be handled differently than Films and TV Shows. I am exclusively using Plex for my music library and I feel very disappointed by this change.
You can disable the grouping into albums, singles, EPs etc. and everything will be as it was before.
Just edit your music library and clear the checkbox.
Hello and thanks for your quick reply. I can’t find the checkbox in plex-web. Where exactly is it?
I am using version 1.24.5.5173
It should be in Settings > Library
It is a drop down rather than a checkbox
Sorry, I misdirected you above.
@blim5001 is correct.
Many thanks guys! :slight_smile:
