I am an early lifetime pass member. I know many of us are very unhappy with your changes to the clients. You need to stop and reverse course or risk a repeat of Sonos leadership replacement from customer exits. I am considering leaving Plex and taking as many with me as I can. You need to put your customers first and not make our experience with your products worse.
I left because of this.
What is the issue though? I’m not following what people say about classic and changes without specifics. I have been using plex for years and can’t really tell the difference.
Sure I’ve noticed some changes to the UI and the application on iOS. But nothing that is in a negative way. Some things are missing though, like the ability to set IPv6 only for remote streaming but allow IPv4 within the LAN so clients that can’t do IPv6 or its not enabled in the plex client can still continue to work without headaches. but these things are minor design and technical flaws that should have been picked up from the start, and it has major impact on those who turn on IPv6 only and then find themselves in a debug hunt that might be over their heads.
This is just an example, but since you haven’t stated any specifics, maybe this scenario applies to you as well but within another category?
The new interface on Android TV is awefully slow !
10+ seconds to start a movie. The menu is a mess, you need to enter 2 differents menus to delete a file.
Conclusion: Slow + not user friendly… I’ll stop using Plex if it’s not improving soon
