How can I fix the order audiobook tracks are arranged?
I’m having an issue with an audiobook where tracks are ordered wrongly. Track 10 through 19 are ordered before track 2.(see image)
Does anyone know of a workaround where I can order tracks chronologically?
You need to number them like this
Track001
Track002
Track010
Track011
Track100
Track101
Of course that does not give anything more than the correct order Plex still lacks anything resembling true audiobook support.
If your using a Music type library. Set the track numbers in the ID3 tags, or if you don’t want to do that you can set the track numbers via the edit screen in Plex Web (see below).
Is there anything on the horizon to be able to store Audible Audio Books on my DLNA so they aren’t categorized in Music? I would like to be able to access my hundreds of audio books from my tablet or laptop when I am traveling and since the travel is work related I cannot store them on my company laptop or computer. The file format is .aa which I believe is a AAC coding.
