How can i make an custom search with DVBLogic TVButler ?
Hi there,
I am trying to set up an TVButler on an Synology NAS, but it dosent find any channels - i search in Romania cable TV.
If i search with DVBLink app on synology it works like a charm, it finds all tv and radio channels. I search in custom mode : 306000kHz,H, 6900, 64 QAM.
My cable provider is RCS RDS (DigiTV).
Is it any way i can search like this in PLEX TV and DVR?
Many thanks in advance.
PS: I look in Plex Log and it only search in xxxxxxxxKhz, V, 64QAM
ct 11, 2017 18:59:22.270 [0x7fe0fe5a1700] WARN - [E] onetv_factory::StartDevice. Device 1:2 not found
Oct 11, 2017 18:59:22.271 [0x7fe0fe5a1700] WARN - [E] CTVSStreamSource::LoadAndInitDriver. Failed to start device path 1:2, type 2, frontend 0
Oct 11, 2017 18:59:22.271 [0x7fe0fe88f700] WARN - [E] CTVSChannelScanner::Tune. Failed to tune to a transponder
Oct 11, 2017 18:59:22.271 [0x7fe0fe88f700] WARN - [E] dvb_channel_scanner_t::scan_networks. Tune failed for 360000,V,6900,QAM64
Oct 11, 2017 18:59:22.271 [0x7fe0fe88f700] WARN - [E] channel_scanner_t::scan_thread_function. Network scan failed
Oct 11, 2017 18:59:22.271 [0x7fe0fe88f700] INFO - * CTVSStreamSource::Term. Waiting for streaming thread to stop
Oct 11, 2017 18:59:22.321 [0x7fe0fe88f700] INFO - * CTVSStreamSource::Term. Streaming is stopped
Oct 11, 2017 18:59:22.321 [0x7fe0fe88f700] INFO - * CTVSStreamSource::Term. Stream source is stopped
Oct 11, 2017 18:59:22.321 [0x7fe0fe88f700] INFO - * channel_scanner_t::scan_thread_function finished
Oct 11, 2017 18:59:24.397 [0x7fe0ffd11700] INFO - * web_service_t::process_device_status
Oct 11, 2017 18:59:24.397 [0x7fe0ffd11700] INFO - * onetv_factory::DeviceGetListEx >>
Oct 11, 2017 18:59:24.398 [0x7fe0ffd11700] INFO - * onetv_factory::DeviceGetListEx. Found device 1060:9824
Oct 11, 2017 18:59:24.399 [0x7fe0ffd11700] INFO - * onetv_factory::DeviceGetListEx. Found device 62464:62464
Oct 11, 2017 18:59:24.399 [0x7fe0ffd11700] INFO - * onetv_factory::DeviceGetListEx. Found device 7449:256
Oct 11, 2017 18:59:24.399 [0x7fe0ffd11700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:3
Oct 11, 2017 18:59:24.399 [0x7fe0ffd11700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
Oct 11, 2017 18:59:24.399 [0x7fe0ffd11700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1
Oct 11, 2017 18:59:24.399 [0x7fe0ffd11700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:36
Oct 11, 2017 18:59:24.401 [0x7fe0fffff700] INFO - * web_service_t::process_get_networks
Oct 11, 2017 18:59:24.401 [0x7fe0fffff700] INFO - * onetv_factory::DeviceGetListEx >>
Oct 11, 2017 18:59:24.402 [0x7fe0fffff700] INFO - * onetv_factory::DeviceGetListEx. Found device 1060:9824
Oct 11, 2017 18:59:24.402 [0x7fe0fffff700] INFO - * onetv_factory::DeviceGetListEx. Found device 62464:62464
Oct 11, 2017 18:59:24.403 [0x7fe0fffff700] INFO - * onetv_factory::DeviceGetListEx. Found device 7449:256
Oct 11, 2017 18:59:24.403 [0x7fe0fffff700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:3
Oct 11, 2017 18:59:24.403 [0x7fe0fffff700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
Oct 11, 2017 18:59:24.403 [0x7fe0fffff700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1
Oct 11, 2017 18:59:24.403 [0x7fe0fffff700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:36
Oct 11, 2017 18:59:24.403 [0x7fe0fffff700] INFO - * device_manager_t::scan_get_networks. Device dvb#tvbutler#0#1:2
Oct 11, 2017 18:59:24.405 [0x7fe104536700] INFO - * web_service_t::process_get_scanners
Oct 11, 2017 18:59:24.405 [0x7fe104536700] INFO - * onetv_factory::DeviceGetListEx >>
Oct 11, 2017 18:59:24.406 [0x7fe104536700] INFO - * onetv_factory::DeviceGetListEx. Found device 1060:9824
Oct 11, 2017 18:59:24.406 [0x7fe104536700] INFO - * onetv_factory::DeviceGetListEx. Found device 62464:62464
Oct 11, 2017 18:59:24.406 [0x7fe104536700] INFO - * onetv_factory::DeviceGetListEx. Found device 7449:256
Oct 11, 2017 18:59:24.407 [0x7fe104536700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:3
Oct 11, 2017 18:59:24.407 [0x7fe104536700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
Oct 11, 2017 18:59:24.407 [0x7fe104536700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1
Oct 11, 2017 18:59:24.407 [0x7fe104536700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:36
Oct 11, 2017 18:59:24.462 [0x7fe0ff735700] INFO - * web_service_t::process_get_channels
Oct 11, 2017 18:59:24.462 [0x7fe0ff735700] INFO - * onetv_factory::DeviceGetListEx >>
Oct 11, 2017 18:59:24.463 [0x7fe0ff735700] INFO - * onetv_factory::DeviceGetListEx. Found device 1060:9824
Oct 11, 2017 18:59:24.463 [0x7fe0ff735700] INFO - * onetv_factory::DeviceGetListEx. Found device 62464:62464
Oct 11, 2017 18:59:24.464 [0x7fe0ff735700] INFO - * onetv_factory::DeviceGetListEx. Found device 7449:256
Oct 11, 2017 18:59:24.464 [0x7fe0ff735700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:3
Oct 11, 2017 18:59:24.464 [0x7fe0ff735700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
Oct 11, 2017 18:59:24.464 [0x7fe0ff735700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1
Oct 11, 2017 18:59:24.464 [0x7fe0ff735700] INFO - * onetv_factory::DeviceGetListEx. Found device 32903:36
Oct 11, 2017 18:59:24.464 [0x7fe0ff735700] WARN - [E] web_service_t::process_get_channels. No tuner(s) in ds_channel_scan_finished state on device dvb#tvbutler#0#1:2
Oct 11, 2017 18:59:56.236 [0x7fe0ff447700] INFO - * web_service_t::process_get_scanners
