@teunissen.pj said:
I’m using TV Butler on windows with Plex and it doesn’t find any channel. NextPVR does find channels and looks clear in good quality. I tried first with plex (did not have any other tv software installed), checked functioning with NextPVR to make sure hardware is working. What can I do to fix it? I live in the Netherlands Ziggo Rotterdam (43146). Do you need the official TV Butler software? I just installed the drivers, nothing else.
Log:
Jul 08, 2017 21:07:36.357 [5484] INFO - * add_filter (Microsoft DVBC Network Provider)
Jul 08, 2017 21:07:36.361 [5484] INFO - * TuningSpace Name: ‘Antenna’ NetworkType: {00000000-0000-0000-0000-000000000000}
Jul 08, 2017 21:07:36.361 [5484] INFO - * TuningSpace Name: ‘ATSC’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Jul 08, 2017 21:07:36.361 [5484] INFO - * TuningSpace Name: ‘ATSCCable’ NetworkType: {0DAD2FDD-5FD7-11D3-8F50-00C04F7971E2}
Jul 08, 2017 21:07:36.361 [5484] INFO - * TuningSpace Name: ‘AuxIn1’ NetworkType: {00000000-0000-0000-0000-000000000000}
Jul 08, 2017 21:07:36.361 [5484] INFO - * TuningSpace Name: ‘Cable’ NetworkType: {00000000-0000-0000-0000-000000000000}
Jul 08, 2017 21:07:36.361 [5484] INFO - * TuningSpace Name: ‘DD2 DVB-C’ NetworkType: {DC0C0FE7-0485-4266-B93F-68FBF80ED834}
Jul 08, 2017 21:07:36.361 [5484] INFO - * Enumeration found 6 tuning spaces
Jul 08, 2017 21:07:36.362 [5484] INFO - * Found TuningSpace
Jul 08, 2017 21:07:36.362 [5484] WARN - [E] cannot initialize the tuning space
Jul 08, 2017 21:07:36.363 [5484] WARN - [E] CTVSStreamSource::LoadAndInitDriver. Failed to start device path @device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1e90}, type 2, frontend 0
Jul 08, 2017 21:07:36.363 [4736] WARN - [E] CTVSChannelScanner::Tune. Failed to tune to a transponder
Jul 08, 2017 21:07:36.363 [4736] WARN - [E] dvb_channel_scanner_t::scan_networks. Tune failed for 164000,V,6900,QAM64
Jul 08, 2017 21:07:36.363 [4736] WARN - [E] channel_scanner_t::scan_thread_function. Network scan failed
i have exactly the same problem! i’m running tv butler on windows server 2008r2 with only drivers installed. is there anything i can try? otherwise i have to return tv butler as long as i have the right to return it :neutral:
**Aug 04, 2017 18:54:24.212 [2396] WARN - [E] cannot create network provider
Aug 04, 2017 18:54:24.212 [2396] WARN - [E] cannot create network provider filter
Aug 04, 2017 18:54:24.212 [2396] WARN - [E] CTVSStreamSource::LoadAndInitDriver. Failed to start device path @device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1e90}, type 16, frontend 0
Aug 04, 2017 18:54:24.212 [1684] WARN - [E] CTVSChannelScanner::Tune. Failed to tune to a transponder
Aug 04, 2017 18:54:24.212 [1684] WARN - [E] dvb_channel_scanner_t::do_scan. Tune failed for 999000,QAM256
Aug 04, 2017 18:54:24.212 [1684] INFO - * channel_scanner_t::scan_channels. Scanned 140 transponder out of 140. Channels found 0
Aug 04, 2017 18:54:24.212 [1684] INFO - * CTVSStreamSource::Term. Waiting for streaming thread to stop
Aug 04, 2017 18:54:24.275 [1684] INFO - * CTVSStreamSource::Term. Streaming is stopped
Aug 04, 2017 18:54:24.275 [1684] INFO - * CTVSStreamSource::Term. Stream source is stopped
Aug 04, 2017 18:54:24.275 [1684] INFO - * channel_scanner_t::scan_thread_function finished
Aug 04, 2017 18:54:26.197 [2452] INFO - * web_service_t::process_device_status
Aug 04, 2017 18:54:26.197 [2452] INFO - * device_reactor_t::get_device_list (dvb#bda#usb#vid_1d19&pid_0100#af0102020700001#)
Aug 04, 2017 18:54:26.197 [2452] INFO - * dvb_device_factory_t::get_device_list (dvb#bda#usb#vid_1d19&pid_0100#af0102020700001#)
Aug 04, 2017 18:54:26.197 [4064] INFO - * DeviceGetListEx_impl: Filter [SI2168 DVBC BDA Filter]
Aug 04, 2017 18:54:26.197 [4064] INFO - * DeviceGetListEx_impl: device instance path usb#vid_1d19&pid_0100#af0102020700001#
Aug 04, 2017 18:54:26.212 [4064] INFO - * DeviceGetListEx_impl: Filter [SI2168 BDA Filter]
Aug 04, 2017 18:54:26.212 [4064] INFO - * DeviceGetListEx_impl: device instance path usb#vid_1d19&pid_0100#af0102020700001#
Aug 04, 2017 18:54:26.212 [4064] INFO - * DeviceGetListEx_impl: pDL->Count:2
Aug 04, 2017 18:54:26.212 [2452] INFO - * dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1e90}, Name SI2168 DVBC BDA Filter, Standards 31
Aug 04, 2017 18:54:26.212 [2452] INFO - * dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1f6d}, Name SI2168 BDA Filter, Standards 31
Aug 04, 2017 18:54:26.212 [2452] INFO - * device_manager_t::get_device_list. Device SI2168 DVBC BDA Filter, id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1e90}, tuners 1, state 5, standards 31
Aug 04, 2017 18:54:26.212 [2452] INFO - * device_manager_t::get_device_list. Device SI2168 BDA Filter, id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1f6d}, tuners 1, state 0, standards 31
Aug 04, 2017 18:54:26.212 [2452] INFO - * web_service_t::process_get_scanners
Aug 04, 2017 18:54:26.212 [2452] INFO - * device_reactor_t::get_device_list (dvb#bda#usb#vid_1d19&pid_0100#af0102020700001#)
Aug 04, 2017 18:54:26.212 [2452] INFO - * dvb_device_factory_t::get_device_list (dvb#bda#usb#vid_1d19&pid_0100#af0102020700001#)
Aug 04, 2017 18:54:26.228 [0800] INFO - * DeviceGetListEx_impl: Filter [SI2168 DVBC BDA Filter]
Aug 04, 2017 18:54:26.228 [0800] INFO - * DeviceGetListEx_impl: device instance path usb#vid_1d19&pid_0100#af0102020700001#
Aug 04, 2017 18:54:26.228 [0800] INFO - * DeviceGetListEx_impl: Filter [SI2168 BDA Filter]
Aug 04, 2017 18:54:26.228 [0800] INFO - * DeviceGetListEx_impl: pDL->Count:2
Aug 04, 2017 18:54:26.228 [2452] INFO - * dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1e90}, Name SI2168 DVBC BDA Filter, Standards 31
Aug 04, 2017 18:54:26.228 [2452] INFO - * dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1f6d}, Name SI2168 BDA Filter, Standards 31
Aug 04, 2017 18:54:26.228 [2452] INFO - * device_manager_t::get_device_list. Device SI2168 DVBC BDA Filter, id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1e90}, tuners 1, state 5, standards 31
Aug 04, 2017 18:54:26.228 [2452] INFO - * device_manager_t::get_device_list. Device SI2168 BDA Filter, id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1f6d}, tuners 1, state 0, standards 31
Aug 04, 2017 18:54:26.416 [2408] INFO - * web_service_t::process_get_channels
Aug 04, 2017 18:54:26.416 [2408] INFO - * device_reactor_t::get_device_list (dvb#bda#usb#vid_1d19&pid_0100#af0102020700001#)
Aug 04, 2017 18:54:26.416 [2408] INFO - * dvb_device_factory_t::get_device_list (dvb#bda#usb#vid_1d19&pid_0100#af0102020700001#)
Aug 04, 2017 18:54:26.416 [3588] INFO - * DeviceGetListEx_impl: Filter [SI2168 DVBC BDA Filter]
Aug 04, 2017 18:54:26.416 [3588] INFO - * DeviceGetListEx_impl: device instance path usb#vid_1d19&pid_0100#af0102020700001#
Aug 04, 2017 18:54:26.431 [3588] INFO - * DeviceGetListEx_impl: Filter [SI2168 BDA Filter]
Aug 04, 2017 18:54:26.431 [3588] INFO - * DeviceGetListEx_impl: device instance path usb#vid_1d19&pid_0100#af0102020700001#
Aug 04, 2017 18:54:26.431 [3588] INFO - * DeviceGetListEx_impl: pDL->Count:2
Aug 04, 2017 18:54:26.431 [2408] INFO - * dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1e90}, Name SI2168 DVBC BDA Filter, Standards 31
Aug 04, 2017 18:54:26.431 [2408] INFO - * dvb_device_factory_t::get_device_list. Id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1f6d}, Name SI2168 BDA Filter, Standards 31
Aug 04, 2017 18:54:26.431 [2408] INFO - * device_manager_t::get_device_list. Device SI2168 DVBC BDA Filter, id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1e90}, tuners 1, state 5, standards 31
Aug 04, 2017 18:54:26.431 [2408] INFO - * device_manager_t::get_device_list. Device SI2168 BDA Filter, id dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1f6d}, tuners 1, state 0, standards 31
Aug 04, 2017 18:54:26.431 [2408] INFO - * device_manager_t::scan_get_channels. Device dvb#bda#0#@device:pnp:\?\usb#vid_1d19&pid_0100#af0102020700001#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{cacacefd-1b5f-49f4-af24-0ce559cc1e90}
