How do I chose different agent
I am trying to fix a match on a movie in Plex but the only agent I can select is Plex Movie:
I want to use the information on TMDB.
This is how the Agents are set up in the server settings:
This is a mini-series and not a movie.Apocalypse: Never-Ending War (1918-1926): Season 1 (2018) — The Movie Database (TMDB)
Therefore you will only get metadata when you place this into a library of the type “TV Shows”
Thanks for your reply but this is not relevant. This was just one example but it is the same with every item I select to fix the match.
I only have the option to select Plex Movie.
See another screen here of a real movie (and yes it is in a library of which the content is marked as movies, not tv shows):
I found the solution myself. Had to go into Manage Library > Edit > Advanced. The Agent there was set to Plex Movie. After I changed this to TMDB I got the option in the fix match on top of the options Plex Movie and Personal Media
