How do I make the Photo Library go away?
Server Version#:1.13.8
How do I get rid of the Photo Library? I’m not interested in displaying photos via the Plex Server. I deleted the library but it is still listed in the library section. I’ve switched off anything that referenced to photo’s. I’ve just switched on iCloud photo library on my computer and it’s downloading everything from the cloud to my computer. The Plex Server is madly scanning the photo library which it should not be doing. I’ve shut down the server while the download is going on. When the download is complete and I restart the Plex Server I suspect it’s going to scan the photo library which I don’t want it to do. How do I make this go away? Thanks.
Just delete the library. (this only removes library, not files on your computer)
Or you can edit the library and just remove the folder that has those photos in it if you want it looking at a different folder of photos
52%20PM
I had done that and as I suspected after the download when I relaunched the Plex Server it started madly scanning the Photo Library again. Did the delete again and now the Photo library seems to have gone away. Thank you for the reply.
