The Plex Series Agent assigns episode files of a “foo - lorem ipsum (2024)” to a different “bar - lorem ipsum (2022)”
How I’m sure the agent itself has a problem:
- some of the words used in the name of the series are used in both series titles
- I renamed the folder and one episode file to “blabla (2024)”
- nothing is assigned as expected
- I renamed the folder and one episode file to “foo (2024)” so it does not contain any word of “bar - lorem ipsum (2022)”. If I search “foo y:2024” at TMDB, it returns only the expected “foo - lorem ipsum (2024)”
- Plex assigns the episode to “bar - lorem ipsum (2022)”, which makes absolutely no sense
I even tried some international alternative titles of TMDB like the french title or only parts of it. In all cases it assigns it to “bar - lorem ipsum (2022)”, so there must be an indexing error in the Plex Series Agent database.
But how do I report this?
Update: The same error happens if I use the syntax “foo (2024) {tmdb-123456}”. So it seems the Plex Agent has merged both tmdb ids internally.
