How does locked data get overwritten after save?
How is it possible for locked metadata fields to be overwritten?
Thanks. I have been matching and changing files as necessary. Thanks.
This is a problem that has been reported more than once over the past 4 years at least. Plex seems reluctant to acknowledge that it is a bug.
If you have manually set the lock on a field, NOTHING should be allowed to change the contents of the field except manual edits.
Same thing here. Plex, is there a solution ? Why have a lock if it doesn’t lock ? It changes all of myu artowrk after I spend time editing with correct metadata. Want to fix it again but I dont want to waste my time if the issue is not even addressed. Plex, help please.
Any plex pros have any ideas or fix ?
It would be appreciated.
I have the same thing happen. It changes the Collection tags, Content Rating and Poster even when there is a lock on those items.
