Server Version#: newest
Player Version#: Chrome
ok, so i had rename the Anime series bleach for it to recognize the content correctly. then plex removed it from the library. I have tried creating new folders, renaming everything. all my files are named Bleach - so1e1.m4v ect. I got so frustrated i made a new library going to the same folder. and it found all the episodes correctly. so how I am guessing there is some sort of data that is blocking bleach from the original library. so how do i get rid of it, or get plex to rebuild the library so it includes all the folders. thanks EDIT: I have tried the scan library function several times, and it wont add it to the library.
Plex Dance…
- remove the show folder to a location outside of this library
- scan library for updates
- empty trash
- clear bundles
- confirm the files / folders are named correctly and move them back into place
As for naming the files correctly… not sure this is a typo or if you named your example that way on purpose. Schema should be:
TV Shows
Show Name
Season XX
Show Name - sXXeYY - optional episode title.ext
where…
XXis the season number -
YYis the Episode number within that season -
extis the file Extension
