Hi There,
I’m new to plex and I had everything configured on my Plex account, but how to I add a personal movie library, I have a lot of movies from my trips and I don’t want to put them all with my ordinary movies, I want to have two different folders inside the movie MENU, I would prefer to have a Personal library. Is it possible to achieve ?
yes you can add personal video libraries that are separate from movie or tv libraries
You can do this by: on the home screen finding the library section on the left side and hovering over it this allow you to hit the plus sign and add a library. At this point select “other videos” (see below) and then you will need to tell plex to find this library.
