How to add missing actor
I have a movie (The Redhead and the Cowboy, 1951) that does not have any actors listed. I would like to add “Glenn Ford” so that when I create a playlist of his movies this movie shows up. Is there a simple way to do this?
First:
Second:
Name it:
The Redhead and The Cowboy (1951)
Third:
Refresh Metadata
and if that does nothing…:
Forth:
Name your files correctly and Plex goes to TMDB/IMDB and gets the cast list and those actor images. There currently is no other way to get Actor Info other than through Matching.
(You can ‘Fix Match’ - under the dots on a Movie’s Preview Page)
(Deploy proper naming and you won’t have to Fix Match every time you add something)
Ok I figured it out. It was using Plex Movie instead Movie Database. It was finding a cover but no actors. Now it is.
TY
