Server Version#:ARMv7 x13
Hello everyone,
When I start Plex media server from my DSM NAS I seem not to see the server section as mentioned here: https://support.plex.tv/articles/206225077-how-to-use-secure-server-connections/
How can I do this change?
How to Enable Secure Connections
Enabling the ability to connect securely with your Plex Media Server is actually really easy. In fact, in a default installation, there isn’t even anything special you need to do, since things will already be set up for you.
- Secure connections require Plex Media Server version 0.9.12.3 or newer. So, make sure you’re running a current version of the server.
- Sign in to your Plex account in the server.
- Under Settings > Server > Network in the Plex Web App, make sure that the Secure Connections preference is not disabled (we recommend leaving it at the default setting of
Preferred).
