How to choose video if i have 2 video for the same movie?
it is not possible to choose the video file on plex web (work on apple tv for exemple) if i have 1 video VO and 1 video VF (french) for the same movie.
could you implement this existing feature on plex web ??
thanks
you should see a “Play Version” off the triple dot menu?
It wont tell you which version has which audio though!
You could also split the movies to 2 separate entries. And then manually change the title. Like for example have The Avengers [English] and The Avengers [Francais]. Or just use the French title and English title, if they are different.
I’ve actually done that for a couple of movies like Donnie Darko and Apocalypse Now, where I wanted both the theatrical cut and director’s cut in my library.
