OH never realized but there is a Serenity tv episode. But it’s episode 11. You’re saying it’s episode 1?
I don’t know what this mean? What is On Deck?
- On Deck is the list of TV Show Episodes you have in progress at any given time on the Home Page - or should be (I guess):
Besides Firefly, these are other common shows that require switching to DVD (or absolute) order if you want to watch it as the creators intended:
- Futurama
- The Critic
- Batman: The Animated Series
There’s also a separate issue where an episode airs multiple parts as one episode, and is listed as such in IMDB, but TheTVDB separates each part into a separate episode. An easy example is Animaniacs. This is a real pain in Plex.
Gotcha. Never really use home page much. I just go straight to my movie or tv show category.
Thx.
Thanks for the heads up.
Are you sure it’s matching against The Movie Database? It looks like it might be matched against TheTVDB, which has very different season/episode information. Try performing a Fix Match for the show and manually select The Movie Database in the Search Options section.
You’re right. I assumed the database sites have the same info for this show but they don’t. Matching it against The Movie Database worked. Thanks.
