Server Version#: 1.42.2.10156
Sorry if this might be dump but is there a way to use TVDB for TV-shows?
I have a dedicated anime library set to TV shows and it uses “Plex TV Series” as scanner.
However many anime season 2 are not recognized as Plex seems to use TMDB instead of TVDB for scanning.
TMDB often has only 1 season with all episodes, while TVDB has the correct seasons. I handle eerything via Radarr and Radarr does the default naming.
One example is Dan Da Dan
- TVDB (correct, all seasons) https://www.thetvdb.com/series/dandadan#seasons
- TMDB (incorrect, has only one season with all episodes in that single season) https://www.themoviedb.org/tv/240411
Others are Kaiju Nr 8 (TVDB, TMDB) it works correctly as soon as I move the files manually from
Kaiju No. 8/Season 02/Kaiju.No.8.S02E01
To
Kaiju No. 8/Season 01/Kaiju.No.8.S01E13
However, that obviously breaks Radarr + I would like to have everything correct. Is there any way around it?
Thank you very much.
