How to disable lock screen image when Plexamp is active
Server Version#:
Player Version#: 3.2.2
Can’t find an option to disable album art on my lock screen; don’t want it to override my default.
I suppose this is about Android?
Only found this discussion on the Android support pages of Google:
Yes, Android (thought I’d tagged that?)
Plexamp changes my lockscreen to the currently playing album art, but I can’t find a setting to disable that feature. Your link is somewhat related, and also mentioned that Google Play has (had) a setting to control that feature.
hmm, as far as i know we’re not doing anything specific for that, and it’s Android which is choosing to use it. i might be wrong.
OK, I appreciate you checking on that.
