I’m new to DVR. Yesterday I setup my new HDHomeRun Connect. I run the setup without issues. The only thing I found is that some channels guide info weren’t found and PMS disable the channels. Could it be possible to enable the channels without guide info?
BTW HDHomerun app has no problem loading all channels guide only PMS can’t.
It’s not possible right now in the current PMS. The only “work around” is to try different zip codes from your OTA market and hopping you will find one that will fill up all the channels. See this post:
