How to fix cropped poster art
New server and all Poster art work is cropped how do I fix this ?
Can you show some examples of what you mean?
you can see TV Shows are normal poster art
You movie library is using ‘Personal Media’ as its default agent.
Which makes the library into a ‘Personal Videos’/‘Other Videos’ type of library.
Edit your library
go to the ‘Advanced’ tab
and set
Scanner= ‘Plex Movie Scanner’
Agent=‘Plex Movie’ or ‘The Movie Database’
