I have all the seasons of Wallander (UK) on my Plex server & just added Season 3 of Wallander (the original Swedish language series) & Plex has unfortunately matched this Wallander series as Wallander (UK).
I thought that it used to be that you could fix a match at Season or individual file level but now don’t see an option except at the root Wallander (UK) level which of course doesn’t fix my problem.
Does anyone have an idea how I can fix this mismatch?
That has never been a thing.
If I understand the issue and these two shows are in separate show folders, go to the show level and choose Split Apart. This will create two Wallander (UK)'s split based on the folders they are in. Then do a Fix Match at the show level to manually choose the Swedish version for whichever one needs it
In the primary show folder
Wallander (UK) (2008) {tvdb-83925}
Wallander (2005) {tvdb-82505}
You might be able to get away with just putting the (UK) or the date for each
Finding a way to split them is ok if you can do it but this will happen again if you ever have to rebuild your server
Split Apart worked OK. Thank you for the very fast response.
I already used Split Apart before I used your post but have modified the names of the root folders to include the TVDB tags. Thank you.
