How to move media without it showing as new?
I have a movie folder on one drive, and want to move some of them to a movie folder on another drive. Typically when I do this they end up showing up in on the home screen as newly added. How do I avoid them showing up as new? Thank you for any assistance!
The short of it is:
  1. disable automatic emptying the trash
  2. copy the data to the new location
  3. add the new location and let Plex re-scan the library
  4. items should now show as duplicates
  5. remove the files from the old location
  6. re-scan the library – if required manually trigger Empty Trash
Edit: If your library is using an older agent / hasn’t been updated for some time you might want to refresh metadata before doing this. Otherwise you might end up with the newly added items being associated with a new agent ID that’ll not match the old one and therefore show as a new item again
https://support.plex.tv/articles/201154537-move-media-content-to-a-new-location/
How can that happen?
Plex removed the duplicate badge - so most people won’t have any idea if the movies are duplicates or not, will they?
  1. should read:
    When the files have copied and Plex stops working on the copy (the disks stop turning, the gears stop whirring) - you can ‘Assume’ everything is duplicated (and hope to all that is holy it has been).
They’re still duplicates – you can filter for them or you can double-check the versions field in on the details page. No reason to hijack another thread with this discussion.
