On Pluto-TV is a series of The Johnny Carson show seasons, names like Season 2 / The Best of Carnac.
Since this is a collection of shows per theme from different seasons, how should I name the directories so Plex will recognize the entries?
You can try to find the “butchered” version of the show here https://www.themoviedb.org/ or here
https://thetvdb.com/
If you find it there, then you can use the show title and episode ordering as listed on either of these sites.
But if you can’t find it, you must resort to the following:
Find out the original season and episode number of each episode and name the files accordingly: https://support.plex.tv/articles/naming-and-organizing-your-tv-show-files/
(look them up on the above mentioned metadata services)
