ok i have 90 days fiance in its own directory. I also have 90days fiance pillow talk in its own separate directory. also all the other 90 shows in the same way. file names are the show title for example 90 fiance s01e01 and 90 days fiance pillow talk s01e01. Yet for some reason I’ve yet to discover, plex like to put all pillow talk under same icon regardless of the show they belong to or the directory they belong to. any one have a way to correct this?
Show the directory listing. TV is very specific.
Yes i’ve read that but i still can’t figure it out. It used to work fine awhile back but than after an update it started doing this. I’ve been using plex for many years and never had a problem with naming of the shows. so i know i follow the nomenclature correctly. or maybe not in this case.
They updated the Movie and TV scanner, looking up the show on TMDB (where Plex looks first) it is named Pillow Talk (2019). So the directory would be something like
TV\Pillow Talk (2019)\Season 01\After The Dust Settles S01E01.mkv
Copied too much removed the second Pillow talk.
i checked TVDB and i saw that they classified al the different pillow talk under the same heading as pillow talk with all the different aliases. That kind of sucks as we wanted to keep the separate as they really should be. I haven’t really found a work around to this.
When plex looks at the files for the first time, it has to determine what show it is. It looks at the folder name and basically does a search on TheTVDB.com for that show. If the folder matches closely to what it finds on TheTVDB, it decides THAT is the show.
Then, it digs into the subfolders within, and starts looking for files with SxxExx format in their name. Whatever it thinks the show is, it picks any file numbered like S01E01 in their name and decides that is season 01 episode 01.
If Plex sees two “90 days Fiance” folders (or closely-named shows) in your TV shows folder, it might think they are both the same show, and thinks you might just have two copies of the show. Despite naming the individual files “90 days fiance” it doesn’t matter, since the folder itself got matched to a different show.
Basically, the best success is to set the folder itself to match - as closely as you can - to the display name on TVDB. In particular, 90 Day Fiance (2014) and 90 Day Pillow Talk (2019). Use those names as the folders and you are likely to have success with Plex matching them automatically and separately. It’s now a good idea to include the release year of the show as well. It’s hard to find the year of the show in the page itself for a show, so do a search, the search results will have the year it came out. (Like this search.)
Make sure to do the Plex Dance. Move the folders somewhere that Plex is not looking at. Change the names of the folders. Re-scan the TV Show Library. Empty Trash. Move the newly-renamed folders back into the location. Scan. They should show up separately.
For stubborn cases you can use the TVDB number in brackets on the show directory level, for the Pillow talk it is Pillow Talk (2019){tvdb-363739}.
Let your Shows/episodes naming follow what’s on themoviedb
Your shows:
Name like this
- Root of TV Library
- 90 Day Fiance (2014) {tmdb-61575}
- Season 01
- New Couples New Journeys -S01E01.<File.ext>
- Season 01
And note in above, that we for Show directory has both year as well as tmdb ID in there to assist the Plex Agent
And as others has already said, after renaming, do the Plex Dance
