How to name Hooked on Phonics
I just fished out a very old DVD set of Hooked on Phonics. I’m not sure I can even rip all the discs given their current state.
However, in case I’m successful, I looked it up on tvdb and tmdb and did not find any entry so I don’t know how to name the files so that I get metadata and the like about them.
Does anyone know of a source, agent, or other way of giving metadata and if should treat it like a TV show or a bunch of movies
Metadata for educational content is very hard to come by.
Maybe these videos are also available here? https://www.youtube.com/hookedonphonics
Or maybe you can find descriptions etc. on their website: https://www.hookedonphonics.com
My guess would be that the only viable way would be to create .nfo files for these videos. Then use the new support for nfo files in a dedicated TV Show library in Plex: https://forums.plex.tv/t/plex-nfo-agent-forum-preview/936104/1
Thanks. I’ll give it a shot then get back to you tomorrow once I’ve ripped all the items that I can. I may use the YouTube channel for anything that is on a damaged disc.
