Can’t find this setting in my Plexamp, prefer just liking a track, currently see the below only.
The setting got tri-state, so it went into Rating System.
Thanks for the clarification. Meaning the single star system work just like the
. If so ![]()
yes, exactly.
Is there a way to have the search also work on downloads when offline? (Using the Android version 3.4.7)
Not currently.
QUESTION - is there a field, or combination of fields, that I can use to create a playlist of “albums” that are actually singles or EPs?
I would like to create a filter/playlist based on an album’s total number of tracks.
For example, an “album” with 1 or 2 tracks would be considered a single, an “album” with 3-5 tracks might be considered an EP, and “albums” with >5 tracks would be considered an LP (or album).
I haven’t been able to create the appropriate filter criteria.
Thanks in advance…
we’d like to use metadata to offer this as a first class thing in the future.
I am using Library Radio and my question is if it is posible that it will not play songs with one star.
Fairly sure it does not play 1 or 2 star rated songs in any of the radios.
Elan,
Yes, I am referring to Singles that are actually Singles and EPs that are actually EPs. Right now everything is considered an “album” in the metadata.
I agree that using the metadata to differentiate these media would be ideal.
Thanks,
Joe
Can we look at adding manual servers into PlexAmp? I have a portable server in my RV and it would be great to be able to easily connect when I don’t have an external connection.
What is meant by “got tri-state”?
I’ve been a subscriber for well over a year, but it’s just this past month I finally decided to invest whatever time is necessary to do a Plex deep dive.
Learn the ecosystem & nomenclature.
Memorize the best practices.
Familiarize myself with even the deepest hidden menu options, settings, & capabilities!
(My GOD there’s a LOT your ecosystem can do & integrate 8nto/with in learning now!!)
… but my vernacular is still in dire need of serious Plex Polish!
…?Did I JUST come up with a catchy new header/blog title/forum thread for people wanting to do exactly what I’m doing?!?
Going from simple remote player, to full fledged, deeply integrated multimedia service & node hub?!!
Hint hint
I LOVE Plex more every day I learn about it!!
Instead of just 2 possible states, it has now 3.
Lol. Thank you my friend.
I understood that right off the hop, so, I should have phrased the question like this: What are these 3 states specifically.??
There is a preference around time window to consider a “recent” play. There is no such preference around ratings that I’m aware of.
He opens mouth and inserts foot
Blushes
I misunderstood, and am wonderfully embarrassed!
Thank you for your timely correction!
I shall delete my foolishness!
