It seems that Plex, for some unknown reason, doesn’t remove missing files from the library, but insists on just keeping them there. Like, say, I have moved files around and now for several TV-shows Plex shows duplicates for each episode, except that it says one of those duplicates isn’t available as the entry points to the previous location.
So, my question is rather simple: how do I make Plex forget all the files that are unavailable?
PLEX retains metadata in the event you have a drive disconnected it doesn’t kill off alot of content. To clean up metadata go to The Plex Dance ™. All steps, in order, do not vary from the instructions and this will fix you up
That is not what the instructions say. However, you might get a good result by right clicking the library>>scan library, and empty trash. BUT if you moved/changed a lot then the dance is the way.
Yes, like I said, the problem isn’t Plex not finding my files, the problem is Plex showing duplicates for my files, not removing the old entries for files after I moved them.
The other commenters already made it rather clear that there is no way of removing the unavailable, duplicate entries without going through the song-and-dance of removing everything from the library and re-scanning it all.
No, just re-scanning the library and emptying trash doesn’t work.
Please post a screenshot of the Plex media info of one affected item.
I am specifically after the folder path and file names which appear at the top.
Are these different or are they identical?
If they are different, is one of them marked as “unavailable”?
Both /mnt/Storage/Video and /mnt/8t/Video exist and are accessible, I just moved the show from one to the other. I did this for multiple shows and they all exhibit this same behaviour, so going through each of the hundreds of episodes manually and removing the unavailable one is a pain in the rear-end.
