How to Run a Custom Build of PMS in Docker
To test a custom build of PMS in a Docker container (such as Unraid), you will need the full URL to the build in question, e.g., https://downloads.plex.tv/plex-media-server-new/1.41.6.9685-d301f511a/debian/plexmediaserver_1.41.6.9685-d301f511a_amd64.deb.
Steps:
- Open a Shell in the Container
Open a shell in the container using the command line or the “Open Console” option in the Unraid container context menu.Here is a cleaned-up markdown version for the custom Plex Media Server (PMS) Docker build process:
docker exec -it plex bash
- Stop the Plex Service
From the container shell, stop the Plex service while keeping the container running:
./plex_service.sh -d
- Download the PMS Package
Download the Ubuntu .deb package for your architecture (normally x64):
curl -o /tmp/pms.deb <URL>
- Install the Package
Install the downloaded package using dpkg:
dpkg -i /tmp/pms.deb
- Clean Up the Package File
Remove the .deb file now that it is installed:
rm /tmp/pms.deb
- Update the Version Number
Update the version.txt file to reflect the build number you’re testing (use the full version including the Git SHA, e.g.,1.41.6.9685-d301f511a):
Note: This is required so that it doesn’t downgrade to the previous build you had installed if you restart the container.
sed -i "/^version=/c version=1.41.6.9685-d301f511a" /version.txt
- Restart the Plex Service
Start the Plex service again:
./plex_service.sh -u
- Exit the Container
Exit the container shell:
exit
