How to see douplets now?
Earliere you could easy see when plex thought there was 2 of the same movie - how do you spot it now? - its very often it thinks 2 completly diff. movies are the same .. but its kindda hard to spot it in a categori with 400+ movies when it dont get tagged visible - maybe moved to a setting i dont know about?
There’s basically 2 ways to approach this:
  1. You can filter your library for duplicates
    Bildschirmfoto 2022-01-09 um 12.50.27
  2. On the movie details page you will see the available versions next to the video/audio/subtitle details.
You just saved my YEAR!
