There is no option to filter movies having "multiple editions"
In movies, I have a filter for “duplicated” movies (duplicated=have different versions), but I can’t filter movies with multiple editions.
I have several movies badly identified as the same (and they’re not, they show a +1, and when I enter to each one and see it’s filename, they’re different movies), but having them badly idenfitied is not them issue right now.
The issue is that there is no option to filter them, and “Duplicated” does NOT show them.
I can’t manage movies with multiple versions if I cannot filter them.
What can I do to list them?
Server Version#: 1.30.0.6486
Player Version#: web, 4.96.3 (but happens on native w64, android, android tv… everywhere)
There is a filter for movies with an edition tag on them.
I didn’t saw it. But it’s empty. It doesn’t show them.
I think that is actually the issue. :thinking: :wink: (If I have read your problem correctly)
The “+1” only shows up (at least on my server) if the same movie is in two different libraries. Since you have mismatched movies, Plex thinks you have the same movie in both of the libraries. You need to correct the mismatched movie. This might actually be the closest thing to a filter you will find.
The “Duplicates” and “Edition” filters are library specific. They only search the library you are currently in. They won’t find items in another library.
I think if you put both of the movies that show up with the “+1” in the same library, then the “Duplicate” and “Edition” filters will work properly for you. Even better when you have the movies matched.
They are on the same library.
This case, I just made It myself to demostrate It, It’s not a mismatch.
I added the new version of this movie. Plex added It as a version (same movie, 2 different files.) It appeared on duplicated.
I separated It. Now It appears with the +1 as a edition, but It won’t appear in the filter Edition. ( It’s the las 2 screenshots.
