How to setup Hauppage 950Q and Plex Pass DVR
I have TV Tuner Hauppage 950q using next PVR and that works fine. When I try to add it to PLEX, PLEX does not recognize it. I have no idea what the network or IP address or HOSTNAME is, so not sure how to add it…??
same issue. i have a 950q on windows 10
Same here on Ubuntu 16.04.2 LTS. Tuner log has:
Jun 01, 2017 18:54:21.272 [0x7fa45f7fe700] INFO - * device_manager_t::get_device_list. Device WinTV HVR-950, id dvb#v4l#0#/sys/devices/pci0000:00/0000:00:12.2/usb1/1-5, tuners 1, state 0, standards 24
950q is not supported, so you can’t set it up. It is another tuner we are considering adding though.
Thanks for the response!!
OOPS I see you support the 955Q not the 950Q, My bad. Thanks.
Would br GREAT if you did add it though.
+1 for 950q
Please do!
@cscottjones87 said:
Please do!
+1 for the 950Q
Another for the 950Q
Upvote on this!! I too, have a 950q!!
Another vote for the 950Q please
I’d love to see support for the 950q as well
add me to that list
I have the 950Q also. Please support!
+1 for 950Q support.
+1 for 950q support
+1 for 950q suppport. I have 3 of them just sitting idle and would LOVE to use them.
