how to setup plex for 3D
So, im about to try out 3D for the first time on my benq w1400 projector. And for that im obviously using plex. :slight_smile:
But im a little unsure on how to set things up for that on plex.
any help would be appreciated!
not sure what kind of info you need to help me out, but here goes.
Viewing with: BenQ W1400 Projector (Active 3D Playback, Active Shutter 3D)
Connected to: Onkyo TX-NR636 (3D Video Pass-through)
Playing with: OpenPHT (and PMS ofc. Im always at the latest versions available for non-plexpass user)
Cables: At the moment im using a Supra HF100 HDMI-cable, so im pretty sure i have to buy a new one.
https://forums.plex.tv/discussion/175633/3d-playback
It’s mostly just how the files are named.
Ok, so theres no way of making Plex just pass-through it and letting the projector decide which output it should use?
Im thinking as i have full discs that is able to play as both SBS and OU. it would be nice to just switch between the modes in the projector.
if i rename the files i guess it will be locked/forced to play in the output i renamed it to?
As far as I know, yes. I mean you have to encode the file one way or another anyways, no? I am fairly certain the discs have multiple versions of the video to switch modes like that. There is nothing in the meta data for the file to indicate that it is one or the other unless I am overlooking it.
General
Unique ID                                : 184259714608982498552089188014132840020 (0x8A9F21543200349496AA8075D57C4654)
Complete name                            : U:\3D Movies\Abraham Lincoln Vampire Hunter 3D.h-sbs.mkv
Format                                   : Matroska
Format version                           : Version 4 / Version 2
File size                                : 7.64 GiB
Duration                                 : 1 h 45 min
Overall bit rate                         : 10.4 Mb/s
Encoded date                             : UTC 2014-04-29 02:49:26
Writing application                      : mkvmerge v6.6.0 ('The Edge Of The In Between') built on Dec  1 2013 17:55:00
Writing library                          : libebml v1.3.0 + libmatroska v1.4.1
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate                                 : 8 093 kb/s
Width                                    : 1 920 pixels
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.220
Stream size                              : 5.82 GiB (76%)
Writing library                          : x264 core 142 r2431 ac76440
Encoding settings                        : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x3 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=8093 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language                                 : French
Default                                  : Yes
Forced                                   : No
Audio #1
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Mode                                     : 16
Format settings, Endianness              : Big
Codec ID                                 : A_DTS
Bit rate mode                            : Constant
Bit rate                                 : 768 kb/s
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 kHz
Frame rate                               : 93.750 FPS (512 spf)
Bit depth                                : 24 bits
Compression mode                         : Lossy
Stream size                              : 577 MiB (7%)
Language                                 : French
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : DTS
Mode                                     : 16
Codec ID                                 : A_DTS
Bit rate                                 : 1 509 kb/s
Bit depth                                : 24 bits
Stream size                              : 1.11 GiB (14%)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #1
Format                                   : PGS
Muxing mode                              : zlib
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Language                                 : French
Default                                  : Yes
Forced                                   : No
Text #2
Format                                   : PGS
Muxing mode                              : zlib
Language                                 : English
Default                                  : No
Forced                                   : No
sorry, but im not sure i understand what you mean.
Why would i encode it? Its a full blu-ray disc as an .iso. no need to encode.
and yes, the disc is capable of playing as both SBS and OU, thats why i want to be able to choose that by myself and not naming the files so plex chooses for me and propably locks it so i cant change which way the 3d is sent (sbs or ou) other than renaming the file again…
Hmmm…
I’m also lost here.
PMS cannot play .iso files…
You MUST encode the file in 3D from the BD disk you have…
I have hundreds of 3D titles (Many I created myself from 2D) My TV will play either top-bottom or side-side 3D formats.
Plex plays them fine.
Not sure if that was even your question
LOL
oh, i thought i could play .iso in plex. guess ill have to find another player then.
not gonna encode (lose quality) just to be able to play it in plex.
LOL
You DO NOT lose quality in Plex!!
The weak link is how you make your Blu-Ray Rips… (Encode)
Plex serves up 4K just perfectly for me…
Oh BTW… 3D is actually lower resolution. Actually something like 720p so both left and right images can play on a 2K TV…
LOL
why dont you just read what i wrote one more time before you answer…
i said “just to be able to play it in plex”. didnt mention anything about plex making the quality worse.
i said encoding made it worse.
and what you are talking about is half-sbs or half-ou.
and one last question. the two settings in plex regarding stereoscopic 3d
“playback mode of stereoscopic 3d videos”
“stereoscopic 3d mode / current”
what are the recommended/best settings for those?
Emby can play ISOs so that might be your only Plex-like option for now until they add that feature or if they do. There are lots of players that can do it, but they are nothing like the Plex/Emby client/server setup.
actually im just looking for something that can play 3d iso. and does it well. doesnt have to be some htpc setup like plex. just some good mediaplayer like powerdvd would do.
