Rasplex? Is that similar to OpenElec? I have tried that for 3D-MVC.
Of course any player can play TAB/SBS
What is “Zidoo X9”? Hardware player or a software package?
OK, I have found some info. This sounds incredible!
https://www.zidoo.tv/Product/index/model/Z9S/target/2INlOr7QH%2B1KKmVViAFMcQ%3D%3D.html
Amazon sells it for $160:
Does it play Plex since it’s Android or do you have to use their interface only? It says it can connect to the Android store of course, but if this thing can play Plex and do all it says it can it sounds like an amazing box, and for about the same price as a Shield!
I wonder what this is compared to the X9S?
https://www.zidoo.tv/Product/index/model/X8/target/WhrwiBL1anZKKmVViAFMcQ%3D%3D.html
Found an answer:
Essentially a SATA port and 16GB storage instead of 8GB.
I’ve heard good things about it. But to get the best experience I think you’ll need to run their version of kodi and use the plex addon.
If I hadn’t had an shield today, that is what I would have went for.
Just wanted to say thank you for this - just applied your fix and it’s working perfectly now.
Hi there panni, just wondering if you are actively looking for feedback on this development fork? Big fan of plex for kodi but having issues since kodi updated to 18. Discussion of same here: (ONLY FOR SERIOUS TESTERS) Bleeding Edge Testing Releases
Thanks a mill
Hey there!
I know this is an older thread, however, thanks to you ricelid i managed to get it working. However, for some reason, i am still having issues with the resume function, where it starts the movie from scratch. Anyone have any suggestions? i’m still using 17.6 64bit i believe, as it was more stable than anything else, madVR, DSplayer and plex for kodi. Any advise would be appreciated IF someone sees this thread
Also, anyonw know where best settings can be found for this setup on madVR. I am VERY VERY new to LAV filters, etc… ie. i have no idea what to set via DSPLAYER .
