So your Plex server is able to communicate with your STB so it tune the channel and you got the stream?
Yes, EPG are in a xml file. I have a script (and a config file to the script) on my CentOS server that create the xmltv.xml file. The script can also create m3u file for software that can use Enigma2 STB as IP TV source like TV Mosaic.
Can you share with how you interface SiliconDust HDHomeRun tuners so the team behind HRTunerProxy can make changes so it is possible to connect Enigma2 STB’s with Plex?
STB : VU+ Solo2 (now testing on this) Image : VTi 13.0.12 HRTunerProxy version : 4.0 Plex version : 1.13.8.5395 Plex server OS type and version : CentOS 7
Currently I can’t get any signal out of Plex anymore either, although it used to work fine. I always get a “en error has occured” message. The green competitor still works fine without issues.
I forgot to add, that this only happens on some of the channels, not all. So probably a different problem than yours…
