Thank you for providing the diagnostics from the special builds provided to you and for a copy of the database.
Appears to be a regression that has led to some requests to the server taking a long time to complete - leading to timeouts at the plex client end. There appears to be a database data fetch that is taking a long time and with 43 libraries that long fetch is multiplied 43 times leading to excessive time to complete the one request which is collecting data from all the libraries.
The diagnostics are being looked into by our development team.
Cool. Iām still using your last diagnostic build as it seems for some reason more accessible than the last production build.
Iām also adding a few things from time to time. Hope that isnāt a problem. Iām guessing you have enough stuff to work with. Tell the team thanks and good luck.
Are the bugfixes in this Alpha already incorporated in the latest 1.18.5 Build? Having the same issues. Would very much like to try if it fixes my problems with all 1.18.x builds.
It has the changes for speeding up server database transactions that were causing timeouts and failure of Plex client apps connecting to the server - seen on servers with many libraries.
(Performance) Speed up connectivity tests and library discovery (āŖ#10930ā¬)
1.18.6.2348 is a later build than alpha build 1.18.6.2342
So please do update. Development / Alpha builds should not be used once there is a later official release build
