Huge icons appeared again
Server Version#: 1.27.2.5929
Player Version#: 4.84.1
The latest version of Firefox seems to have caused the same problem as I hit previously in this thread: Plex Web Version 4.61.2
The icons have suddenly become huge again. I have checked that there are no further updates for either the server or the browser app. Any ideas what has caused this again?
Is no-one else getting this?
what version of firefox. does it happen in any other browser? are you using a custom screen resolution on your computer
It is the latest version of Firefox v102.0.1 64 bit. I get the same thing on Waterfox, I don’t get it on Edge.
No custom screen resolution.
I had this before, as you can see in the link within the first post, and it went away either with a Plex browser app update or a Firefox update. I can’t remember which it was.
I’m not seeing this on my Firefox. (same version)
Verify that you have no browser add-ins activated. Try the “privacy mode” to see if it makes a difference.
Very strange: I disabled the two plugins, refreshed the Plex page and the icons went back to normal. I then re-enabled the plugins one by one, firstly the DRM plugin because Plex told me it wanted it, and then the H264 video codec. The icons remained at their correct size.
I closed Firefox and restarted it. The icons stayed correct. I had previously restarted Firefox several times hoping that an update in something would clear the problem but it didn’t.
I didn’t update the plugins or anything. Any idea what happened here?
I’m not talking about plugins. I mean add-ins. Things like AdBlock, NoScript, or Stylus.
Maybe your browser just needed a cleanup of caches.
I understand. I was working through that but it appears that it is not the add-ons, it was something to do with the plugins. Very strange that disabling and re-enabling them fixed the problem.
