like 1 month ago an annoying thing started, the icons turned bigger than they were and somehow they now overlap and is very annoying
any way to make them smaller again ?
can you say if something is happening like a library scan or some movie is started on a tv? hardly i can tell you … very hard to spot that number 1 there
I had this happen with one of my browsers, but it was horribly out of date, so I put it down to that.
If you are using the Windows app, though, I hear a re-install of the app fixes it. Try uninstalling then re-installing the app.
Use https://app.plex.tv
or download and install the latest Plex player for Windows/Mac manually
