I need to get with both the Chrome team and the Transcoder guys.
This is not making any sense.
- Hardware is detected.
- HEVC capability detected.
- Hardware not used by ChromeOS.
This is a chromecast or ??
this is not chromeos.
The client this is LG TV webos.
The server is a synology ds218+.
Then Iām very curious why itās reporting ChromeOS
Jan 09, 2020 15:11:50.233 [0x7fa713735700] INFO - [ui-chrome-webos] [Player] Can play AUTOMATIC? true
Jan 09, 2020 15:11:50.233 [0x7fa718435700] DEBUG - Completed: [10.0.0.115:54908] 200 POST /log (9 live) GZIP 0ms 274 bytes (pipelined: 29)
Jan 09, 2020 15:11:50.333 [0x7fa718723700] DEBUG - Auth: authenticated user 1 as dwang5@gmail.com
Jan 09, 2020 15:11:50.333 [0x7fa710af4700] DEBUG - Request: [10.0.0.115:54908 (Subnet)] POST /log (9 live) GZIP Signed-in Token (dwang5@gmail.com)
Jan 09, 2020 15:11:50.333 [0x7fa710af4700] INFO - [ui-chrome-webos] videoResolution: 2560
Jan 09, 2020 15:11:50.333 [0x7fa710af4700] INFO - [ui-chrome-webos] bitrate: 25414
Jan 09, 2020 15:11:50.333 [0x7fa710af4700] INFO - [ui-chrome-webos] useSoftSubtitles: true
Jan 09, 2020 15:11:50.333 [0x7fa710af4700] INFO - [ui-chrome-webos] canDirectStreamAudio: false
Jan 09, 2020 15:11:50.333 [0x7fa710af4700] INFO - [ui-chrome-webos] canDirectStreamVideo: false
Jan 09, 2020 15:11:50.333 [0x7fa710af4700] INFO - [ui-chrome-webos] canDirectPlay: true
Jan 09, 2020 15:11:50.333 [0x7fa710af4700] INFO - [ui-chrome-webos] canPlay: true
Jan 09, 2020 15:11:50.333 [0x7fa710af4700] INFO - [ui-chrome-webos] [MDE] Finished analysis of 4k (mkv, hevc, eac3, 150, main 10)
Jan 09, 2020 15:11:50.334 [0x7fa710af4700] INFO - [ui-chrome-webos] [Player] Can direct stream? true (isAllowed: true)
Jan 09, 2020 15:11:50.334 [0x7fa710af4700] INFO - [ui-chrome-webos] [MDE] Starting analysis of 4k (mkv, hevc, eac3, 150, main 10)
Jan 09, 2020 15:11:50.335 [0x7fa710af4700] INFO - [ui-chrome-webos] [MDE] Augmented profile: { "directPlay": { "mp4": { "mimeType": "video/mp4", "video": { "codecs": { "h264": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 8, "maxLevel": 51 }, "hevc": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 10 } } }, "audio": { "codecs": { "aac": {}, "mp3": {}, "ac3": {}, "eac3": {}, "dca": {} } } }, "mpegts": { "video": { "codecs": { "h264": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 8, "maxLevel": 51 }, "mpeg2video": { "maxWidth": 1920, "maxHeight": 1080, "maxBitDepth": 8 }, "hevc": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 10 } } }, "audio": { "codecs": { "aac": {}, "mp2": {}, "mp3": {}, "ac3": {}, "eac3": {}, "dca": {} } } }, "mov": { "video": { "codecs": { "h264": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 8, "maxLevel": 51 }, "mpeg4": { "maxWidth": 1920, "maxHeight": 1080, "maxBitDepth": 8 } } }, "audio": { "codecs": { "aac": {}, "ac3": {}, "eac3": {}, "dca": {} } } }, "asf": { "video": { "codecs": { "vc1": { "maxWidth": 1920, "maxHeight": 1080, "maxBitDepth": 8 }, "wmv3": { "maxWidth": 1920, "maxHeight": 1080, "maxBitDepth": 8 } } }, "audio": { "codecs": { "wmav2": {}, "wmapro": {}, "ac3": {}, "eac3": {}, "dca": {} } } }, "mkv": { "video": { "codecs": { "h264": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 8, "maxLevel": 51 }, "vc1": { "maxWidth": 1920, "maxHeight": 1080, "maxBitDepth": 8 }, "vp9": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 8 }, "mpeg4": { "maxWidth": 1920, "maxHeight": 1080, "maxBitDepth": 8 }, "mpeg2video": { "maxWidth": 1920, "maxHeight": 1080, "maxBitDepth": 8 }, "hevc": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 10 } } }, "audio": { "codecs": { "aac": {}, "mp3": {}, "vorbis": {}, "ac3": {}, "eac3": {}, "dca": {} } } }, "avi": { "video": { "codecs": { "mpeg4": { "maxWidth": 1920, "maxHeight": 1080, "maxBitDepth": 8 }, "mjpeg": { "maxWidth": 1920, "maxHeight": 1080, "maxBitDepth": 8 } } }, "audio": { "codecs": { "aac": {}, "mp3": {}, "pcm": {}, "ac3": {}, "eac3": {}, "dca": {} } } } }, "directStream": { "video": { "codecs": { "h264": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 8, "maxLevel": 51 }, "hevc": { "maxWidth": 3840, "maxHeight": 2160, "maxBitDepth": 10 } } }, "audio": { "codecs": { "aac": {} } } } }
Given itās LG helps knowing. Iām forwarding this to the app team for their help
Ok, That didnāt take long.
Not the news you wanted but this is where it stands.
Ok the limitation is with Plex or LG?
Who is working on that?
I also see the same issue with the android client running on my phone. Does the android client also have the same limitation?
here are the logs when using the android client if it helps.
Phones? Yes, they do. They are all Android - based
The Windows version of the server does the streaming differently because of how it can render the subtitles. Even hardware transcoding is handled differently. Windows has its own ālayerā to do everything.
Iāve got the same problems - scrambled picture when trying to use PGS subtitles, and constant buffering even when NOT using subtitles. Iām using the latest version of Plex Server on my DS218+ - āPlexMediaServer-1.18.4.2171-ac2afe5f8-x86_64ā playing to Nvidia Shield TV.
Whatās going on? Is there a server version available that ISNāT broken?, How do I get it and how do I downgrade versions?
Itās described just upstream in this thread.
Where? Described by who?
@ChuckPa I am not on synology, but I have a similar problem.
I thought it was the new player version to be blamed, but then I stumbled on this thread.
I am on a custom nas running openmediavault (linux 4.19 kernel) with an Intel Silver j5005 Gemini lake processor which was fantastic until some days/weeks ago.
Plex is ran in docker container (linuxserver, with ālatestā plexpass tag).
This issue appeared recently, it also occurs on the plex dvr TV channels which requires transcoding. Unwatchable. Green block, stutter with almost no image.
As soon as I disable hw transcoding, the picture is flawless, but my cpu stays in 99%. Is there any other way to avoid this?
LE: failed to find the iHD_drv_video.so on my docker container, so I rolled back to an earlier version (docker linuxserver 1.18.0.1944-f2cae8d6b-ls60). All good now.
I attach my log in case someone can take a look.
Thanks.
Plex Media Server Logs_2020-01-14_21-16-21.zip (1.3 MB)
the file should be in (container relative) /usr/lib/plexmediaserver/lib/dri/iHD_drv_video.so
Thanks, indeed the path for linuxserverās dockered plex:
Since I run a cron job to delete and update all my docker containers every 3 days (thus the driver will be reenabled on the next update), I will stick with an older version until a proper fix upstream.
Better yet, if someone could make a script to run after a docker update to check if the driver exists and if it does, to delete it, please do share. Thatās be amazing.
Thank you!
LE: Worked on adapting a script to my needs
#!/bin/sh
cd $(dirname $0)
COMPOSE_HTTP_TIMEOUT=120
# build/pull updated containers
docker pull linuxserver/.... #your images go here
# restart all the things
docker-compose -f docker-compose.yml down --remove-orphans
docker-compose -f docker-compose.yml up -d
sleep 5s
echo "Restarting docker containers..."
docker exec -it plex /bin/bash -c "cd /usr/lib/plexmediaserver/lib/dri && rm -f iHD_drv_video.so"
docker restart plex
hi all, any updates on the issue?
this issue is known since the end of october. even beta users reported it, still it got released ?
like why ? and this has to be the workaround for 3 months ? what a joke
Download available with fix. Deleting driver, etc not required:
The fixes will be included in 1.18.7 which will be available in Plex Pass beta in the next few weeks. In the mean time, please use the build linked in the thread above.
