I cannot rollback or downgrade below 1.26
Server Version#:1.26
Player Version#:various
I cannot seem to successfully downgrade my server. Like many others in the last week who have upgraded, tried database fixes and other issues, the one thing i cannot do is go back. When i try, my database is corrupted and nothing shows up. I see this is an issue across many platforms, I know I’m not the only one having this issue. Whats up Ninjas?
If you’re downgrading by version, you may have to uninstall, then install. That is the case for Windows.
The database isn’t loading on any version below 1.26.
Try sending a PM to sa2000 with logs, or try using
WebTools-NG - Third Party / Apps & Tools - Plex Forum
