How do I do this? I tried using some help on the internet.
Close the server app. Remove the app. Find the Updates folder and reinstall.
But now Im getting “there was an unexpected error loading this library.” I tried repairing the database but its not working for me. There seems to be two different db repair guides as if some major change happened in a version after 1.22x
I have almost 30TB of content and I’d rather not rebuild everything from scratch using the original 1.22.3.4392 installer.
Everything still works great if I return back to 1.29 but I don’t like the web interface for 127.0.0.1
I will gladly pay money who can solve this if you want.
PMS makes scheduled backups every 3 days or so. On my Mac, they are located next to the running database files, and the backups end with a date.
How to restore them if desired is explained in a plex article.
Below you can see where the files are and their names.
$ ls -l
/Users/nibbles/Library/Application Support/Plex Media Server/Plug-in Support/Databases
total 208816
-rw-r--r-- 1 nibbles staff 9862144 Oct 23 18:04 com.plexapp.plugins.library.blobs.db
-rw-r--r-- 1 nibbles staff 15122432 Oct 13 10:28 com.plexapp.plugins.library.blobs.db-2022-10-13
-rw-r--r-- 1 nibbles staff 15439872 Oct 16 01:00 com.plexapp.plugins.library.blobs.db-2022-10-16
-rw-r--r-- 1 nibbles staff 15715328 Oct 19 01:04 com.plexapp.plugins.library.blobs.db-2022-10-19
-rw-r--r-- 1 nibbles staff 9725952 Oct 22 01:03 com.plexapp.plugins.library.blobs.db-2022-10-22
-rw-r--r-- 1 nibbles staff 32768 Oct 23 19:42 com.plexapp.plugins.library.blobs.db-shm
-rw-r--r-- 1 nibbles staff 0 Oct 23 19:42 com.plexapp.plugins.library.blobs.db-wal
-rw-r--r-- 1 nibbles staff 7859200 Oct 24 00:20 com.plexapp.plugins.library.db
-rw-r--r-- 1 nibbles staff 6977536 Oct 13 10:28 com.plexapp.plugins.library.db-2022-10-13
-rw-r--r-- 1 nibbles staff 7239680 Oct 16 01:00 com.plexapp.plugins.library.db-2022-10-16
-rw-r--r-- 1 nibbles staff 7655424 Oct 19 01:04 com.plexapp.plugins.library.db-2022-10-19
-rw-r--r-- 1 nibbles staff 7669760 Oct 22 01:03 com.plexapp.plugins.library.db-2022-10-22
-rw-r--r-- 1 nibbles staff 32768 Oct 23 19:42 com.plexapp.plugins.library.db-shm
-rw-r--r-- 1 nibbles staff 1055368 Oct 24 00:30 com.plexapp.plugins.library.db-wal
It does sound like the database went through a significant change that warranted two Repair articles. Let’s say instead you choose to downgrade to 1.26 or 1.28.
How to downgrade a running PMS on a Mac
Downgrading is exactly like upgrading. You quit the app and drag a different version into
/Applications Here is a detailed walkthrough.
- locate the PMS icon at the top right of your screen in the the Apple menu bar.
- Right click or 2-fingered click on the PMS icon.
- choose Quit
- In Finder locate in Downloads usually the
Plex Media Server app you’re trying to install.
- Drag
Plex Media Server into /Applications and Replace the one that’s there.
- Reboot the Mac
- Start PMS.
Troubleshooting
You may have to jump though some hoops to administer it or reclaim it. Clearing Safari cookies history cache and using incognito mode helps.
You may want to downgrade to such an old PMS like 1.22 that it causes database problems and won’t start. I have no idea whether that might happen, but it’s not fatal. Make sure PMS is quit and restore a database created from scheduled backup that was made when you were running that 1.22 version.
When you get errors, be sure to screenshot them and drop them into your reply along with server logs.
nibbles!
Wow that was very simple. I went through seven different major revisions between 1.29 and 1.22 VERY QUICKLY. Kudos to programmers, extremely simple.
I figured out what I didn’t like about the new version.
I MISSED THE GRADIENT BACKGROUND!
It was replaced with blue in 1.24 and then black for the native M1 support in 1.28.
Also, I THOUGHT I WAS getting five icons per row but it was only four the entire time!
So I went back to 1.29 and let it go hahaha.
Can I buy you a coffee or something nibbles? PM me a donation link or whatever is appropriate for you.
