Server Version#: DS418j
Player Version#: 4.12.3
Hi guys. I need your help. I accidentally clicked on the option to turn off the option to Remote Access my NAS, and now, my library does not display in the left navigation panel. If I go into the Settings section in the web browser, I have no settings available to click to re-enable Remote Access. If I click on the Plex icon that is on my taskbar and log into the server, there is a Settings section there and I can see the Remote Access option there, but none of the options are available for me to click on. I do see a message telling me that I must “First sign in” but my Synology NAS is not listed - instead, it is referencing my iMac.
Is there an easy way to re-enable all of this?
Please be gentle. I am alone doing all of this and I do not have anyone to help me - except for all of y’all.
This will be tricky on a Synology but can be done.
You need desktop access to DSM if you haven’t already enabled SSH
If SSH is enabled, the next question is: Is it open through the modem/router? (a dangerous configuration).
Presuming you have all that.
ssh into the Synology using the extra options (ssh -L 8888:127.0.0.1:32400 ip.addr.of.syno) or Putty port forwarding 8888 -> 32400 from a Windows machine.
With that session established, let it sit idle. it will serve as the conduit.
Hi Chuck.
Thank you so much for taking the time to help me. Unfortunately, I was not able to get very far with the instructions you provided.
From my iMac, I opened a Terminal session and entered the SSH command you provided, however I was not able to establish a session that allowed me to open the http://127.0.0.1:888/web page in either the Safari, Chrome, or Firefox browsers.
This week has been a bit rough for us, and if I can get at least one thing working for the kids, it would most definitely be a highlight.
Thank you again for your help. It is greatly appreciated.
Chuck,
I got a little further this time. I got through step 1 (port 22 does display). When I go to the Terminal window and enter the information you recommended, I am prompted for a password. I think I have thrown every possible password at it with no luck. It just gives me a “Permission denied, please try again” message. I have been very diligent in keeping track of my passwords, so I am a bit confused as to why I can’t get in.
I am so close…
Thanks again, Chuck. You’re a saint - with LOTS of patience.
Hi Chuck.
My apologies for the delay in responding.
I signed out of the web app as instructed and retried accessing what I needed to using the terminal window and the information to type in. All I got were ssh permission denied errors. So instead, I figured I would try to at least do what you asked to download the Logs, but I cant even seem to find that. Here is what I did:
From my DSM webpage, I clicked File Station, but I could not find anything else that you mentioned in step 3. I am missing something… I am just not sure what.
Thank you for still trying to help me.
