I just updated my OS, which comes with a new software store and what I wasn´t expecting to find there, was Plexamp in the list. I just installed it, signed in and it worked right away.
The look of a modern Winamp, brought a smile to my face. I loved the fact that you guys chose the vertical layout and not a full screen player. I hope we can get lyrics there in the future. Thanks a lot!
Now let me show off, my brand new player
Did you try clicking on the track title? That should have brought up the menu which shows Lyrics listed. This depends on the setup of the server and if Lyrics can be found for those tracks though. I’d find a song thats certain to have lyrics, play it, and see if the menu option appears. If the Lyrics option is shown, then the song has lyrics to display, otherwise if it doesn’t, it won’t appear.
https://support.plex.tv/articles/215238778-automatic-lyrics-from-lyricfind/
You’re right, clicking on those different areas, brings different context menus. Thanks for the tip.
You might want to take a look at [How To] Plexamp 3.0
