I have 2 libraries currently and I want to create a third library that combines both libraries.
I currently have 2 movie libraries (DVD and Bluray). I would like to create a third library that points to both folders so I can get a consolidated listing of all my movies. My Plex server seems to slow down (hours) dramatically as it tries to build the library. I finally quite because it was also affecting the response time on my original libraries.
So my question is can this be done or is it not recommended to have multiple libraries pointing to the same movie folders?
Perhaps you enabled the video preview thumbnails? https://support.plex.tv/hc/en-us/articles/202197528-Video-Preview-Thumbnails
If you’re on Windows, look at Task Manager to see what’s using all your resources. If it’s PlexNewTranscoder.exe, then it’s probably building the thumbnails. If it is thumbnails, then you probably have it set to generate thumbnails when media is added. You can try setting it to generate thumbnails during scheduled tasks so it only generates them during a certain time of the day.
Thanks guys, I will check and test this out later this week. I’m out of town right now and I would prefer to do it when I get home. I will let you know how this works out.
Thanks for your help. By turning off the video Preview things worked a lot better.
