I need help with my Plex pre roll vidios
My pre roll videos are in a folder on my server in ‘Other’ folder. How do I configure one to play before each movie? I don’t know how to create a link to in the address box? Thanks so much :slight_smile:
This should help. https://support.plex.tv/articles/202920803-extras/
So I guess the path wanted is from the server’s perspective?
Edit: Yes, can confirm local path from server’s perspective works. Spaces in path works as well.
yes
you need the full path of each file (not just the folder).
make sure you understand the difference between comma separation and semi-colon
