Issue is explained in the topic. Hope someone knows the answer.
Thanks!..
Thanks!..
I would just restart your Plex app or restart the computer.
Note: My server was just displaying the same issue, a restart resolved the problem.
I’ve seen this kind of thing caused by ad blockers.
Is this server a WD MyCloud Home NAS device?
If so, then you can only use the pre-defined folders and libraries.
Oh well, yes, it is a wd mycloud device. Sad to hear there is no way to do this. I had already deleted the predefined libraries thinking I could create my own and now I won’t even be able to use those.
Thanks to all for all the prompt responses.
