Thanks, Tom for the explanation, but it still won’t help me. I’m currently running into the same issue.
You need to be more specific. What does “can’t connect” mean? Bridge mode isn’t for wifi. I assume set up static is referring to your server behind the usg? What did you put into bridge mode? What provider do you have? What is the current topography from the interwebz to the pms?
As per @djfriday13 ‘s question… which exact aspect is failing for you? Providing some of the findings from the basic troubleshooting will help us helping you:
Turn on UPNP in your router and reboot router and computer and then see if you are still getting the same disconnect. Also, I had trouble even using port 32400 if it was not manually set in the PLEX remote access settings.
