[IMPLEMENTED] Plex Android mobile & TV beta - Live TV & DVR - Partial Recording is now Possible
This issue is present in Android mobile and Android TV version 7.27.0.14941-beta. The background for this topic can be found here.
This issue persists in Android mobile and Android TV version 7.27.0.14964-beta
This issue persists in the official Android release 7.27.0.15018
There has been a development. Refer to this post.
This issue persists in Android mobile and Android TV version 7.28.0.15170-beta
Hi there :wave:
Soorry for the delay and thank you for reporting this :slight_smile:
We are currently working on new player support for Live TV at the moment, which once released will have the ability to record a show directly from within the player. I understand this does not fully solve the problem because you may want to record without even starting playback so we are going to look at some potential solutions to this in the meantime. We do also support pressing the record button on your remote if you have this button, but rest assured we are looking into some potential solutions to this :slight_smile:
Thanks again
Do you have an approximate timeline for when this might be supported. I’m trying to get my Mom off of Windows 7 WMC as it ended support in January but issues like this are preventing me from using Plex.
This issue persists in Android mobile and Android TV versions 7.28.0.15447-beta and 7.28.0.15460-beta
Not intending to harrass you in any way, I understand the dev team are aware of this issue, but I’ll keep ‘touching’ this topic after each beta release to ensure the topic doesn’t close after 3 months.
This issue persists in Android mobile and Android TV versions 7.29.0.15583-beta.
This issue persists in Android mobile and Android TV version 7.29.0.15876 .
I will just leave this here :wink:
You shouldn’t tease… :blush:
Resolved in Android mobile and Android TV version 7.30.0.16082-beta
On Android mobile and TV, a long keypress on a show in progress now brings up a record option. The long keypress also works for future recordings.
@daioio Thank you for following through on your promise :blush:
